Am rebuilding the carb off my SC again; a Zenith 9667. I installed the needle and seat that came with the kit. The new needle is longer that the old one. With the new one installed, it makes the float ride much lower(farther away from the casting) so much so that it barely has any travel between the needle and the stop. I compared the needles from two different kits and they are both this same way. Is it likely to have to shorten the new needle when rebuilding this model carb? I tried this the first time around without much luck.
Thanks,
Paul in MN
Thanks,
Paul in MN
