schebler dlt7?
Im cleaning out my grandfathers shop little by little. He used to fix up 2 cylinders and some other tractors. So I will be popping up from time to time with questions. On the shelf i found a carb. Schebler name on it numbers dlt7 also on it. What did it fit, and is it worth anything? Id much rather someone could find a use for it than scrap it. Everything i can turn on the outside is still free, but it is rust colored. Thanks.
DlTX7 is the number on the bowl. The carb # will be on a flat area near the top of the carb next to the Load Needle. you may need to polish it some with sand paper or a wire brush to see it.
Don't give up on it too quick. There are guys who can repair a lot of stuff on those old cast iron carbs.
I don't have a listing for DLTX 7, so can't help you there.
thanks..its a dltx6..ill do some more research later today, if anyone needs anything off of it, can probably have it for shipping.
