jerry i have used it and i like it in fact boughgt a case of it to have on hand.
i put a little in the fuel tank itself and also i warm up the engine turn it off and put a couple squirts in the spark plug whole replace plugs let it soak overnite remove plugs crank over to remove fluid reinstall plugs and start up.
it helped remove alot of blowby on an old ford tractor i had it did not cure the problem completely. i put some in the crankcase wasn't a good idea it made a rear seal leak even worse al
