Sediment Bowl Screen
super99
Lots of questions tonite. The JD 70 is starting to look like a tractor again. I would like to put a screen on the sediment bowl inlet to tank. I have a screen off of a JD combine, it is the same size as the fuel inlet. I would like to cut the inlet off even with the end of the threads and drill out so the screen will fit inside. The screen is plastic and the sediment bowl is soft metal, should be easy to drill. Do you think this will work? The sediment bowl has a bulit in oil pressue shut off, so just replacing the sediment bowl in not an option. Chris
I like the thought of the extra screen being there. The big drawback I can see is the little screen will plug someday and then the whole sediment bowl unit will have to be unscrewed out of the tank to clean it. Jim
They make small filters to fit into spray nozzles which may work for you. The spray nozzles on spray rigs that spray crops.
if it fits you may not have to cut any thing off.
Super99, if you want some additional screen area ask for a bowl screen for a combine like a 7720. They use the same bowl but a different screen. The screen is not flat and is dished to fit the inside of the bowl. You will more that double your screen area. Last I checked they weren't too expensive, either. Hope this helps. Mike
What you might do is to fit a small piece of tubing to the inlet so you raise the intake point half an inch or so. That will help by not picking up so much crud off the bottom of the tank. I did that on a Farmall that had rust in the tank, and due to baffles, I was unable to get all the rust particles washed out. Only need to be sure you have an inch or more of fuel in the tank. Made my tube out of a piece of discarded car radio antenna. Just happened to fit nicely.
I do the same thing but with plastic tubing. Local store has a variety of sizes, can always find one for a press fit.
There is a screen inside the bowl already. I want to have the vertical screen inside the tank in the event that something gets into the tank so it will not block off fuel inlet. Chris
Don't cut it off. You drill it out and rust will still settle inside of it and plug it so you will still have to remove it all the time.
Use some tubing like others discussed. About an inch or so to keep the rust out. Copper pipe or rubber or plastic hose will probably work fine. I used a piece of screen door screen a couple inches long and wrapped it around the inlet a couple times and then held it in place with a twisted piece of small safety wire around it. Could make your tube with a couple wraps of screen and then JB weld the seam to hold it together and then stick it over the inlet.
