Seeding after corn
showcrop
A landowner is asking me to seed down a field that has been in corn for about five years. The land is glacial till (rocky dirt, no sand or clay) I have done this before and had problems with my disc (JD KBA) cutting in adequately, but there were a lot of weeds last time I did it due to being fallow for two years. This piece has very few weeds. I wonder should I see if I can get a chisel? or turn it over? or just disc it up. This is a separate issue from fertility and pH, as I will go by the soil test for that.
A common disc is a secondary tillage tool- will not make much of a seedbed if it is the only thing used on corn stubble, especially more than a year old. An offset plowing disc is a primary tillage tool, and will not leave a good seedbed, even if run lightly. If you have access to a chisel plow, (wide sweeps in Spring is an excellent option) run that first, (in Spring, not usually full depth) then disc it for a decent seedbed. Good to have a harrow behind as well.
Just discing will work fine for your grasses. But you need to run s spikr tooth hsrrow over it a couple passews after disc. Then a cultipacker before and after seeding.You can seed with one of those spreaders on a four wheeler or a gandy box.
You didn't say how large a field either. If you want good answers putlots of info in your questions.
Gordo
if your stalks are like ours this year a kba won't even cut them, we has a rw once, nice for finishing but not for cutting, my 21' 490 IH doesn't even do alot to them. I would either consider a no-till drill like a 750 jd or plowing them if you want to get a decent stand.
