Serial plate location
Anonymous-0
Where is the serial plate located on a Case DC? It has the eagle hitch and hand clutch.(I don't know if that would make a difference.) Thanks
It should be located on the dashboard. If it is missing from there, then you can find the serial number stamped on the driver's left side of the engine block, on the edge of the flange where the block and transmission bolt together.
