Shipping containers for storage - any experience?
Anonymous-0
Thinking of buying a 40' shipping container to set out on the property to store the tractor and a few tools. Anyone have any experience with them, pros or cons?
They must work.
There is a company here in Iowa that is buying them and renting them out as temperary storage.
Stronger than any building you will build.
Gary
There is no end to what you can do with those containers.
Use them extensively for outdoor scrap tire storage....Waterproof, tough, lockable.
Thinking about converting one into a 4 stall shed row barn myself.
40" should run about $2500
I've talked to a few people who have them, one has had his broken into several times. Apparently a crow bar in the right spot pops them. He beefed that up and someone cut the door pins?
I've seen some nice conversions with roof and siding.
I have a 40 footer I use as part workshop part storage. They are tough, waterproof and make awesome, quick buildings
About break in's on my old job we would open dozens of conatiners a day with a plain old tire iron. Now the cable type locks were tuff to break.
I've been on jobs in NYC where contractors used them for tools, materials and storage, some make jobsite offices or shanty's out of them, just remember there is no ventillation in them unless you modify the container. Gets hot when in the sun. Flammable vapors and such could be a problem, confined space etc. I'm not sure what these guys did to secure them, if thieves are a problem, you may want to improve that, I'd put D.O.T. type placards on the outside labeling it explosives, high voltage, chemicals etc. or something volatile, explosives may not be the right choice, but you get my drift, something that ought to deter someone with a cutting torch or grinder, then again, today some people have no common sense, will try anyway, best to keep nothing valuable in there if you have to worry about theft.
Caveat emptor: Some of these have been repeatedly treated with extraordinary pesticides, the residual of which may actualy be present still. Same goes for dead or "re-cycled" semi-trailers. The ones from overseas would have been under no treatment restrictions of any kind. While the "nose test" might be a sufficient indicator of it's (the pesticide) presence, some of the most toxic can have no odor whatsoever. Just sayin". This is a very unregulated pool to be swimmin" in. Protect yourself and your family first. A good cleaning and washout under the proper circumstances and conditions may well be warranted.
Having said that, I second what everyone else has said. Talk about yer instant strongbox!
I saw one that my second cousin has. He installed sliding windows in it for ventilation, and light. He installed an extintion cord, to run lights, and recepticals for power operated tools. Like someone already said, there is no end to what you can do with them. I'm also thinking posibily in the future of buying one to store some smaller implements in. Cheaper than building an addition onto the machinery shed. No building permits required.
Bruce.
Got one in the back yard a friend has his tuff in it he paid $3500 delivered with a roll up door in the side.
Very pretty inside all wood in nice shape.
Walt
I would think they would make very good storage buildings. Would there be a condensation problem in our part of the country with hot and cold temperatures? They have them for sale here so it musn't bother too much.
They make a great air tight storage container. We have used them at work for a few years now. Keep them closed up and they practically dust free. They will be good for you tractor provided it is a small tractor. Opening is only about 8 ft. I believe.
I have a 40' container in my back yard that we loaded my mother in law's household goods in after she needed to go to a nursing home. It seems to work very well for that: it doesn't seem to leak at all, and the D-con I put in it when we loaded it up does not seem to have ever been touched. When it was delivered, I set it on about 10 railroad ties on a section that had been pretty level lawn. It is secure enough for this location, out in the country, but anyone with a bolt cutter could cut the padlock fairly easily.
There are a few downsides. I don't know what has been shipped/stored in the container before, but it has a strong, lingering odor that gives me a headache if I am in the container very long. I have worried that the odor was from application of pesticides or other possibly dangerous chemicals. This Summer, my wife and her siblings are going to come and look through the container and hopefully haul some of the "stuff" away. I plan to open the container and set up a couple of box fans before they start working in there, since I sure don't want them getting sick. It also gets extremely hot in there in the afternoon sometimes.
The containers come in different qualities. The one I bought is supposed to have been the highest quality my local seller ever gets, almost good enough so the company that previously owned it would keep using it. It was also pretty expensive (I think about $2700 delivered 6 to 8 years ago). My brother bought one for less than $1000, but it is not nearly as tight, and looks like it might have been dropped and crushed a bit. If I had been paying attention, I could have bought another 40' container for about $1500 from a neighbor, but I didn't know he was going to get rid of it.
The containers are not beautiful! Mine still has the reddish brown paint that it had when it was used for shipping. I have seen some that people have tried to paint, and the new paint has not held very well. They look even worse with peeling paint. I suppose it is necessary to prep the surface and prime it just like any other metal.
I have thought about getting another container and setting it up parallel to the one I have and about 24' apart. Then I would build a roof over the space between the containers using standard 24' roof trusses on walls built on the edges of the containers. It wouldn't be hard at all to extend the roof to the other edges of the containers. I don't think there would be any chance of wind lifting the roof system if it was fastened down well and if there was "stuff" in the containers. But I sure wonder what the building codes people would think about my "temporary" structure. With the container I have, I don't think that I am being taxed more for having it, but probably I would be if two were roofed over.
If I was going to use my container for something other than a hardly ever opened storage unit, I would figure out some way to power ventilate it. I haven't noticed any condensation problems, but I live in a fairly dry area. In an area with lots of humidity, I suspect that condensation inside might be a real problem.
Would I buy my container again? Sure. It has already more than paid for itself storing my MIL's junk, rather than paying for storage space each month. It was pretty quick and easy to get set up in my yard. If I had it to do over, I would have used concrete railroad ties, rather than the wood ties. Concrete ties are available in my area pretty cheap, and they would never rot out like the wood ties might. The container is also a whole lot cheaper storage than I could have built using either pole or stick construction, and I didn't have to deal with building codes to set it there.
If you go shopping for a container, look it over carefully for bad damage to the metal and for rotted wood floors. And spend a bit of time inside, to see if there are objectionable odors that concern you. You also might check to make sure that somehow zoning will not allow you to keep it on your property. Good luck!
The only thing I see bad about them is if you are gonna get charged on your property taxes for another building. We have several 45ft van trailers we use on the farm for storage. If the axles are left under them they are still considered a mobile vehicle and thats fine, but if the wheels and axles are taken out from under and they are laid on the ground they are considered a building for storage and you get taxed on them. I know several people in our locale that this has happened too. Needless to say ours are still on wheels. Just a thought you might want to check into. One thing for sure they are built a lot tougher than a semi trailer.
if your going to buy one look for an old reefer one ,already insulated add a few windows and instant shop or building that is easy to climate control .
Hal: I'd think at least one and maybe two good box fans might help the ventilation issue, even if it required a generator. I'd fire them up maybe 15-20 minutes before I need to be in there working. Fresh air will do wonders to curb the headaches I would think. Bigger fans, more volume, more better. It may very well stir up whatever else may be sitting undisturbed in there, hence giving it a few minutes of running ahead of time of need to be in there might serve to exhaust some of the potential contaminants. Yes/no?
