Sickle Bar Tach help needed (MF135)
SWMO 135
I rec'd this cutter when I bought my MF135 deluxe. It was rec'd the same way as it sits in the photos (which I hope work out!) below. I could use all the help necessary to get this thing mounted & operational. Any manuals available for this unit? What to look for in possibly a dangerous operating situation?
Also need help with the tach for the tractor- how can it be hooked up if there is no way visible to mount to alter/generator? Also, there is no cable out the back of tach, but looks like there should be. And a cable driven tach is what I'm used to.
Many thanks in advance-Les
sorry it would only allow 2 photos at a time
Les
PS: in the second(lower) photo in 1st post, the spring and the lever are 2 individual parts.
lg
OK, for some reason, I can't seem to post another photo and this would be the one of the head unit of course! I can tell you that the serial # found on the plate is 0442, thats it, nothing else but a number on the cutting edge side of the head unit casting, it reads M-F and right below that, it reads 413 or 41-3 ? 4-13 ? Anybody got any ideas? or why I can't seem to post more photos? Thanks Again, Les
Les, Ironically the mower is a 135. Yellow in
color sold thru industrial or red thru ag dealers
I do have an orig but lightly used man for $9 with postage. The 135 tractor is probably a gas
model(4 cyl continental)and if the gen was switched to a alt. there went the drive. The gen
has a little gearbox in the back to drive the tach. If it is a Perkins diesel(or Perkins gas)
the drive is at the rear of the camshaft and
drives with a flex shaft. Chuck
Chuck, thanks for such a fast reply. The numbers will make everything a little easier to remember, if nothing else! lol Does the manual you have show both parts and how to operate cutter? If you would prefer to contact me thru e-mail, feel free to do so. Would love to have it, if we can work it out. The tractor is a gas (Continental Z145), but alas, no drive to attach tach cable anywhere on the alt/gen (how can I tell which it is?) It's 12 volt, if that helps. Would you know if there is anyway to hook up a tach in this situation? Would prefer something other than ear to guess at rpms! Thanks so Much for your help on this one (or 2), Les
An alternator is short and fat. A generator is much longer that is in diameter. An alternator is usually aluminum, a generator is usually steel painted black, though the one on my MF-135 is painted silver.
With the Continental engine the tach depended on the gear box on the back of the generator.
The only alternative I've found is a digital tach that will fit the hole and be driven by the ignition system, getting a signal from the points. They can be had (for a princely sum) with hour meter and maybe 3000 RPM full scale on a pointer though most made for auto racing like to be 8000, or 10000 RPM full scale which is useless on a tractor. A digital meter with 10 RPM increments ought to do well, I've seen one like that at JC Whitney in years past.
A tach is very handy on a tractor.
Gerald J.
Gerald, thanks to you also for the reply about tach issue. I was going thru this website for parts after your reply (I have a generator from your description!) and saw a "Proofmeter", which looks like it is made to re-fit a Delco generator w/gear drive for tachometer so a cable may be attached to it? Am I thinking correctly here? Not sure yet if the gen I have is a Delco- but I'll chk today. I don't remember seeing a tag on it, so is there another way to tell what brand it might be? Help w/how to proceed would be most welcome as I totally agree on the "handiness" of a tach.
