Sicklebar for Oliver 1365
Samiam
Hello. Just bought my first tractor, an Oliver 1365. Looks rough, runs smooth. I ordered the manual set a bit ago, and I"ll no doubt have many model-specific questions after I try to digest some of that material. In the meantime, my first 2 attachment needs are a post hole digger, and a mower. I think I"ve identified the PHD I need after doing some research. Re mower - I"ve got 40A raw land (>90% wooded) in the Blue Ridge, but most of the mowing is needed on and adjacent to my access road, including both up and down slopes bordering the road. While I could probably make do with either a brush hog or a sickle bar unit, the layout seems to lean toward the latter (I don"t intend to buy 2 mowers at this time). Anyone have ideas about what I should look for in a sickle bar unit for this tractor? Should I assume that I"m limited to 3-pt/PTO generic units that operate at the rear of the machine, or was there at one time a belly-mounted mower specific to this model? Any other general tips in what to look for in a used sickle bar mower intended mostly for light roadside maintenance, not harvesting? Many thanks in advance for any help.
-Samiam
What kind of dealers do you have in your neighborhood? Buy a mower that parts and service are not too far away. Get a pitmanless one. Around here the townships all do that with disk mowers. One of the first things to check on your tractor is adjustment of both the main & PTO clutch. Change all the filters too.
Suggestion would be to go with a bush hog/mower. Sickle mower's are meant for hay and will break if it encounters objects other than grass.
There are a few mid-mount sickle bar mowers available as after market. Alamo makes a good one but is pricy. I consider this to be the best out there right now.They have a web site. I mowed roadsides for many years (30+)for a living with a sickle bar and they are great. These will reach where the tractor cannot be driven and with good guards and sharp knives cutting a small tree the diameter of your thumb is not an issue. If you are mowing rough terrain, it really has to be a mid-mount. It is too difficult to keep track of what you are about to mow down otherwise. Too, as was also mentioned here, it should be a pitmanless so that it can be run well above or below the horizontal. A new mower should be able to be mounted up to virtually any tractor... check with the dealer first. Good luck with your mowing!
Cal
