So as some of you know i have been working to get my freshly rebuild 8n up to par for a few weeks now on and off. It runs but hasn't run quiet right and lacks power. Also she can be corrected and runs smoother with the choke slightly pulled out. Regardless i don't have a timing light so my cousin headed on over this weekend to help me set the advanced timing on my sidemount 52 8n. I fired up the old girl (already had set the basic timing) and we had the light hooked up. We marked the flywheel on 0 degrees and proceeded to set the advanced timing (his light has degree ofset knob on the back of it). We started by setting the 400 RPM idle at 4 degrees (wasn't much off). Then we headed to the 1200 RPM speed and the timing advance was off... we set it there and moved to i believe 2000 or 2100 RPM and it again was off. There is a each time we moved to a different RPM the timing was off. I'm assuming this is due to bad cam weights or similar in the distributor. By the time we set the 2100 RPM timing and moved back down to 400 RPM to recheck it and see how much it was off it was 34 degrees! I seems bassackwards from what it should be... (advancing as the engine slows)... this is a bit screwy. I'm guessing i'm in for a distributor rebuild.
Any ideas? What all needs replaced?
Thanks, Tyler
Thanks, Tyler
