Simplicity Tractors Refurb Thread.
Fawteen
Location
Downeast Maine
Thought I'd do a "blog" sort of thread on the two Simplicity tractors I bought.
The 3416S is by far the closer to being ready to use of the two.
I made up some new battery cables as the old ones were...ummm..."crude". Popped a known good battery in it and it started pretty easily and ran okay. The carb has what is apparently the standard B&S Large Flo Updraft leak. Fuel leaks out around the emulsion tube. There's a couple of theories on the best way to fix that, I'll try the o-ring fix first.
Treated the seat pan with phosphoric acid and primed it, made a new base for the seat as the mounting holes were all torn out and the seat was flopping around on 2 bolts. Supposed to be 4.
Changed the oil twice as the first batch was REALLY nasty, checked the gear oil in the bevel gear case and transaxle, lubed everything and drove it around for a while. All that's left is to figure out that carb leak and replace some fasteners in the steering linkage with the proper ones.
Next big project on the 3416 will be figuring out and mounting the sickle bar. Fortunately, I have the books for that.
This morning I looked at the other tractor, the 7116H(ydro)
The more I look, the more I find. If you can believe the hour meter, it has 24xx hours on it which is a lot for a lawn tractor, not to mention a B&S engine.
Wiring is a huge mess, I'll have to start pretty much from scratch. What I assume is the rectifier has been hacked with bare twisted connections. I'll be surprised if it works at all. Battery cables and starter solenoid wiring appear to have been cobbled together with whatever was laying around.
Carb is in a box in pieces but at least I've identified a parts source. Fuel tank rattling around loose, but I have what I think are the hold-downs in one of the boxes of pieces-parts.
None of the tires hold air, the front ones are complete trash. Pulled the front rims/hubs off to facilitate changing tires and found the outer bearing missing completely on one, and the other three growling pretty bad. Fortunately, commonly available. Left kingpin/spindle assembly hacked together with keys mangled.
Did a little pre-treatment with phosphoric acid on the battery box and seat pan.
First goal is to get the engine running. If it's pooched, there's no point in messing with the rest of it until I figure out a re-power. I do want to "save" it as it has a hydro trans and hydraulic lift.
Peeled what remained of the tires off the front wheels. I was amazed that my Horror Fright tire tool popped them right off. I was prepared for a struggle, had some new arrangements of verbal lubrication all rehearsed and ready to go too.
Knocked the bearings - pretty sure they used to be bearings - out of the hubs, scrubbed the wheels down good with mineral spirits and I'll toss them in the sandblaster tomorrow. Bearings readily available, I'll order them when I know the tractor is worth saving.
Apparently the previous owner(s) got up close and personal with the proverbial hard place. Repeatedly. After sandblasting, I'll break out the Smoke Wrench and do what I can about straightening the rim.
Fed-UPS dropped off two new Chineseum tires this afternoon. I ordered tubes as well but they're supposed to be tubeless so I'll pull some new valves in and try that first
The 'wavy' on the rim lip was probably from trying to pry the tire off the rim. You can help straighten it a lot with some judicious use of vice grips. If it was me, I would skip the tubeless step and go directly to tubes.
You may be right about that TRK. And I'll have them on hand anyway, so...
I put new fronts on my Kubota and the tire guy looked at me a little oddly when I specified tubes. Told him if I puncture a tube, I can repair it and get one with whatever I'm doing. If I puncture a tubeless tire, I'd have to bring it to him. Time lost and money spent.
Thanks for the reminder on the vice grip trick. Worked slick!
Compressor took a beating running the sand blaster, but it got things reasonably clean. I'll hit them with a coat of Rustoleum Rusty Metal Primer to stop flash rust and put them on the shelf while waiting on bearings.
First major snag.
Switched gears and started looking at the Troy Bilt tiller. It appears someone started to repower it and ran into issues with the throttle/governor linkage and walked away.
I spent an hour studying on it and came to the same conclusion. The Tecumseh governor setup is not compatible with wherever the throttle brackets/linkage/cable came from...I assume Troy Bilt. I can't see a reasonable way to farmer-rig it and I think the best solution is to re-repower it with a Predator engine.
I'm gonna pull the Tecumseh and get some dimensions and see if that's practical. Still cheaper than a new tiller and the old Horse models were built a lot more rugged than the modern stuff.
Here is my 3410S hood slightly not original to the rest. Doubled the HP via Kohler M20 and Hydro Gear transaxle .IMG_20260909_094842851~2.jpg
Started messing with the Troy Bilt tiller. It appears that someone attempted to repower it and chose the wrong engine. No way the throttle and governor linkages are going to work.
After a bit of research I found a HF Predator engine that is a bolt-on. Around $180 which is still way cheaper than a new tiller. Waiting on the cookie jar to refill a bit but I'll post when I'm in the process of doing the repower.
I repowered a Troybilt tiller and a chipper with those engines. Less than $100 each. Ain't inflation great. Both jobs were easy. I think all i had to buy for the tiller was a metric bolt for the end of the crankshaft to hold the pulley on. Can't remember if the threaded bosses in the block to mount the engine were SAE, but i don't remember buying bolts for that. I think I also acquired some machinery washers to space the pulley correctly on the crankshaft. Ok, maybe i bought more than 1 bolt😁. But Ace hardware had everything i needed. The chipper was even easier. So far, I consider both repowers very worthwhile. Only issue so far is the vent hose from fuel tank to carburetor. Cheap hose doesn't like UV and developed holes which let rainwater get into carb when cover blew off. Also kill switch one 1 engine went south, so i have to shut off fuel to kill it. Probably a good idea to run it out of fuel anyway. Good luck.
BTW, I just recalled that i had to get a longer throttle cable for the tiller. I did run it for a while using only the throttle lever on the engine, but didn't really like that.
It's like a Sign from Above.
Got a text yesterday, 30% off on all Predator engines at Harbor Freight today. 6.5hp horizontal shaft engine that's a bolt-on for the tiller, $110 out the door.
The very definition of a no-brainer.
Today's task was to take pieces of 3 carburetors plus a kit to make one good one for the 7116H. I think I have achieved that, but won't know for sure until the ignition is reassembled so I have spark and I mount the carb and test drive it. May be a while.
I ordered the oddball 5/16-32 tap and die to chase the threads on the body and the almost-right parts from the kit. For the moment, I installed a used emulsion tube and needle as the parts from the kit had thread issues, as did two of the three bodies. Boogered threads in the carb body is a common issue, according to my research.
Big day at the mailbox. Wheel bearings came in so I could finish up the front wheels for the 7116H. Pressed the bearing cones into the hubs and then went for the tires.
I had tires, tubes, bead sealer and tubeless valve stems on hand.
Original plan was to mount them tubeless and the first one went slick as a smelt. Popped right on the rim and aired up with no fuss.
Second one made up for it. I could NOT get the bead up on the shoulder far enough for it to take air. After messing with it for most of an hour (and putting a serious dent in my store of verbal lubrication) I tore it back down and stuffed a tube in it. Take THAT, ya expletive deleted!
Also got the 5/16-24 NF hardware so I could bolt the pulley onto the tiller motor. Thanks, McMaster-Carr, I now have a lifetime supply of 5/16-24 x inch-and-a-half bolts and nuts...
So tomorrow - assuming the weather clears on schedule - I'll put the wheels and rebuilt carb on the tractor and mount the motor on the tiller. That should be all that's needed to get the tiller running.
Got the motor on the tiller yesterday and immediately discovered that I needed to make a spacer for the motor pulley to line it up with the transmission pulley.
This morning I yanked the motor back off and wasted a couple of hours on the lathe making one completely wrong spacer (bored it to 7/8 for a 3/4 shaft...doh!
:roll:
) and making a completely unnecessary second one once I realized there was no point in broaching a keyway as the spacer went on BEFORE the key and pully. Dummy.
ANY-way, went back together, got the belts on and went an played in the mud. Works fine. Had to disable the low oil sensor due to the angle of the dangle when the tines are in the ground, and the clutch detent needs a stronger spring but that's a 5 minute job. With that new engine, the tiller should outlast me.
Did get the carb on the 7116 but was missing the link from the governor arm to the throttle shaft. On order from EBay. Amazing that I can order parts for a 50+ year old carb. Love the 'net! Started on the wiring as well as it suffers from multiple issues due to dried out, cracked and missing insulation.
