Slipping clutch
iH welker
I have a 11" clutch in my m with 6 button disc and heavy duty pressure plate and it's slipping since I changed tires .
Going to a 12" need info for a good disc and a pressure plate and the motor is over 400 cubes ,tires is 16.9's
Would like to go bigger than necessary and all help is greatly appreciated
SM 6 button clutch disc, 986 12" pressure plate and SM-450 flywheel. When ordering pressure plate have it built heavest springs as possible. Will hold 200 hp easy
(quoted from post at 17:29:31 01/02/14) SM 6 button clutch disc, 986 12" pressure plate and SM-450 flywheel. When ordering pressure plate have it built heavest springs as possible. Will hold 200 hp easy
Clutches are rated in torque instead of HP.
200 HP @ 2000 rpm would be 525 ft lbs?
most people know the HP of their tractor, but not the tq. most
people would not know if a 500 ft lb clutch would work or not,
but would know exactly if a 200 HP clutch would work.
If we are talking about a farmall m any where near 200 HP, i
don't think we are talking about stock rpm. But i don't think we
are talking 4000 rpm either.
