Slow cranking on D3B
LGoff
I've got an 1987 D3B that drags when cranking. Usually after the machine is warmed up, it cranks better, but overall it just turns slowly. A mechanic told me that these machines are notorious for it, maybe the starter should have had more of a gear reduction or something. Even with a new battery, I have the same problem. Any ideas?
Yes they are known for that, new heavy duty cables have been my fix when I encountered them. D3 dozers/931 loaders
So, the original cables aren't good enough? I'm not sure where I can find a heavier cable than what's on it, or do they just need replacing?
Heavy equipment shops should have a special crimper for making heavy duty battery cables. I know Bowman distribution sells the crimpers. You could have bad connections or internal corrosion on your cables. Clean and check everything first. Another thing to check is the small wires by the starter. I have a Nippon Denso starter on my 86 931B and all of a sudden it wouldn't even click when you hit the starter. Kind of by fluke, I discovered that a small wire from the starter switch to the solonoid was broke. An auto electric place said it was a fusible link because the wire was so flexible. He said it could just be spliced back together and should be soldered. I didn't want to buy a good soldering iron for 1 job, so I used a crimp fitting that also had the heat shrink on it. No problems in over 2 years. The wire had a special size Cat only plug in connector on it, otherwise I would have replaced the whole wire. Cat seems to famous for not using standard connectors or fittings. Dave
