small engine float level
JOB
This friend of mine still has not got his engine to run right and think it could be the float level. I don't have a model number of carb or engine. But the engine is a 8 horse Briggs with a Temcumbse (lawson) carb. Is this enough info or are these carbs all different? Thanks for any advice.
Tecumseh carb on a Briggs and it doesn't run right... HHMMMMM?
That being said, with rare exceptions, 'most all floats sit about level (with the carb top inverted) when set to "spec".
If the carb is at ALL compatible with the engine, and the float level is CLOSE, most likely there's a plugged or restricted passage(s) if the engine isn't running well.
Boy thats a First. I would get rid of the carb. & put the right one on.That carb probably isn t jetted right for the briggs engine.
When you say it doesn't "run right", how is it not running right? Not starting, will only run for a few seconds, will only run for a few minutes, surging, bogging, no power?
Float level being incorrect would likely make it run for awhile then stop as it is not getting enough fuel.......having said that, as already mentioned, you can't just mix and match carbs without knowing all the specs. That is most likely the problem.
Did it ever run right with that carb?
The engine is not mine and I thought it was kind of strange that it had a Tescumbse carb on a Briggs. Maybe he just thinks it is a Briggs. He had bought a carb kit from out of his owners manual and it is a tescumbse and matches what was in the carb. Right now the engine surges and will die like it is running out of fuel. The engine always ran good, the reason for the kit was the needle valve would not shut off the gas. Whatever gas was left in the tank would be gone the next time it was to be used. This engine is on a snowblower so it will not be used tomorrow.
I have offered to stop on the way home and look at this engine. He did bring the carb to work and take it apart and put the new kit in it. I had left the shop when the new kit was put in so I don't know what happened. A float sitting level makes sense. The needle valve and seat not sealing is why this carb was taken apart. The carb was not that dirty on the inside when taken apart so I don't know if he blew anything out before putting it back together.
I HAVE A 5 hp/130000 Series Briggs with a Tecumseh diaphragm carb on it. Of course I have HIGHLY modified the Tec. carb. to set it up for LP fuel. I also built special parts to bolt it to the Briggs engine.
Kent
It's probably a Tecumseh engine. They look similar to a B&S.
The passages in a small engine carburetor are so small that a piece of dirt that would cause a problem may be smaller than you can see. Also, old gas which turns to varnish after it sits can make orifices smaller by building up on the side walls. It is well advised to take it completely apart and clean it with a good carb cleaner and blow it out really well before reassembly.
Surging happens when there is not sufficient fuel. When adjusting it after reassembly, open up the throttle wide open and if it surges, open up the high speed needle (if equipped with a needle not a jet) a little bit at a time until it runs smoothly. If you open the needle too far it will start to sputter and the exhaust will get black. If this happens, turn it in until it runs smoothly and does not surge. If there is no setting that will make it run smooth there is still dirt or varnish in one of the tiny passages. It ain't rocket science but you have to give it a proper cleaning. Had a friend once who didn't do any maintenance on his snowmobile, just shed it every spring and pull it out in the fall. It would drive me nuts because I did all the proper things with mine and I blew the engine twice..........when his finally did blow, it blew real good!!
Thanks Inno, He is going to bring the carb back to work so I can look at it. Carb cleaner sounds like a good idea. I had worked on a few small engines long ago. I needed a refresher. Thanks
Yup, hope it works out. Carb cleanliness is always important but especially so in small engines. That reminds me I have to pick up a fuel filter for my son's little Ariens........and I'll be cleaning that carb this evening!
If it is truly a tec carb on a tec engine I agree with everyone else check the float level when inverted it should be nearly level. There is also a welch plug that needs to be removed to completely clean out the idle circuit of the carb & then a new one installed you just lightly tap the center with a punch slightly smaller than the welch plug. Don"t drive the plug in too deep or you will have to remove & install another plug. You can blow the needle seat out with a blast of air through the gas inlet hose barb or hook the seat with a small piece of wire. When reinstalling if there is a ridge on the rubber seat it goes away from the needle. The engine should run at 11/2 turns on the adjustment screw needle out from seat position. If after this the engine will only idle or run at full throttle someone has tried to adjust the governor spring tension screw, I have only had success adjusting this screw with the throttle set at high speed & use a tach to accurately set the speed to the appropriate full throttle speed which if I remember correctly is 3300 RPM"s. Adjust the needle adjustment at full throttle also turn in slowly until the engine aputters & then turn slowly out until the engine sputters or looses RPM & set in between these two positions. Everyone is correct when they say especially a tec small engine is very picky when it comes to a clean carb, I prefer to pull out the welch plug with all needles & jets out & soak the carb in cold parts carb cleaner. What most people do not know is also the Tech engine needs to have the oil drained I recommend about every 25 hours unless you want to take the chance of throwing a rod as they have a simple oil pump & very small oil pickup screen.
Hope this helps
