Hi.
This message probably belongs in the garden tractor section but we've all got small mowers too so here's the question:
My Kohler Command 25 hp twin on my JD mower is cycling and won't run without choke as if it is fuel starved. The whole air intake system is in order so I figured I'd make the main jet a little richer. I take a look at the motor and the manual and see that the jet is set once electronically at the factory and there is no way to adjust it. There is just an electronic plug into the carb.
What should I do to get this running right again?
thanks all.
thanks all.
