After cleaning the carb on my JD 425 and fixing my runaway issue (my fault - thanks guys) I need to adjust the engine r.p.m.'s. I could do this seat of the pants I guess, but I'd prefer to use a tach vs. launch a piston.
Has anyone used an affordable tachometer for this purpose? I figure I could use it on the rest of my small engines also. I've found a couple on ebay and thought I'd ask what you guys think of them or what you'd suggest.
Here's one: http://www.ebay.com/itm/Tachometer-Hour-meter-2-4-Stroke-Small-Engine-Spark-/180807722705?pt=Motors_Automotive_Too
This one is pretty cheap, it appears to operate by wrapping a wire around a spark plug wire.
Here's another type: http://www.ebay.com/itm/Handheld-Digital-Laser-Photo-Tachometer-RPM-Tach-Small-Engine-Motor-Speed-Gauge-/221013004645?pt=LH_DefaultDomain_0&hash=item337566d165
This one appears to use a light to measure rotational speed. You put a reflective sticker on a rotational part of engine (flywheel?) and the light reads that. I'm not sure I could get that sticker on a good place on every engine I'd like to measure.
Any thoughts?
Any thoughts?
