I notice a slight buzzing noise and tiny vibration coming from the two new hydraulic hoses I installed from the pump to the reservoir. I think this is probably normal, but not sure.
Thanks, Ellis
Normal, in a gear type hydraulic pump the flow out of the pump is slightly uneven due to the change in displacement of the areas between the gear teeth as they mesh on the pressure side of the pump. That may all be moosh talk to you, engineers probably have an even more complex explanation.
