Snow plow (again)
mhdavi
Just waiting for the snow
I would have mounted that on the front. Easier to push forward than backwards. Mount the blade under your tractor belly somehow, and run a cable to your 3-point to raise it.
Yeah I would mount it up front somehow. Tractors will push lots more going forward than going backwards. If your in an area that doesn't get much snow then it probably isn't a big deal I suppose.
I mounted mine on the front of my TO30. I used a winch to raise it that way I could have a blade on the back.
Bob
My drive way is narrow with steep sides. By having the plow in the rear allows me to be able to push the snow back farther and still have good traction on the rear wheels
I now you have chains on , but changing your wheels from one side to the other will reverse the tread and help with traction in reverse.
Just a thought if you have any trouble it may be worth trying.
Hope we get no snow!....Sam
Your blade sticks a long way out from the tractor which could add more stress to everything. I would think maneuverability would suffer as well.
