Contact a paving contractor?Snowplowing my gravel driveway with the 8n and a back blade, how to I prevent the blade from wanting to dig in too deep? I now have a dirt driveway and a gravel yard.![]()
Trial and error. Your 8N has POSITION CONTROL so use that mode to keep height set once you hit the mark and set Touch Control Quadrant Stop. As TOH said, skid shoes can be used. Install stabilizer bars (NOT STAY BARS) - they keep back blade from kicking off to the side under load and help to keep blade running straight.Snowplowing my gravel driveway with the 8n and a back blade, how to I prevent the blade from wanting to dig in too deep? I now have a dirt driveway and a gravel yard.![]()
I turn the blade around, and use the other side, so it doesn't dig in as much. As Tim mentioned, stabilizer bars also make a big difference.Snowplowing my gravel driveway with the 8n and a back blade, how to I prevent the blade from wanting to dig in too deep? I now have a dirt driveway and a gravel yard.![]()
I need to buy a shorter top link.Shorten the top link to roll the blade forward a bit. I never tried the pipe trick, but it sounds like it would be a good idea, too.
I had it rolled a bit too much in the pic below, but it was still moving snow! -10°F, was thankful for that mil surplus parka!
I'm with madfarmer. Drive over the first few inches to make a snow pack.I don't touch mine unless it's frozen, or so much snow I can't move my truck.
Top LNKS are adjustable ---what do you mean you need to buy a shorter one?I need to buy a shorter top link.
I need to buy a shorter top link.UH, and you want to buy a new top link because why? What is the matter with the one you have? You do know they are adjustable, right?
If your lane is mostly 15% grade with sharp turns that strategy gets a bit edgy.....I'm with madfarmer. Drive over the first few inches to make a snow pack.
edgy. i see what u did thereIf your lane is mostly 15% grade with sharp turns that strategy gets a bit edgy.....
TOH
TOH
Foot good - rolling resistance and some traction.edgy. i see what u did there
i have one short steep stretch, and the rest is as flat as a pool table. until there's more than a foot, i'm driving thru it.
I installed a set of shoes like on snow plows on mine, adjust the height so it suits you and it works great. Plus you get to weld something and that's always a good day!
Basically, you have to find a piece of shafting, around 1" and two short pieces of pipe that the shafting will fit in somewhat loosely. Then get or make a couple of really heavy washers you will weld onto one end of the shaft. Find someone with a heavy press, and push on the welded shaft with a piece of big pipe under the edge of the washer, which will put a crown in the washer. Weld or bolt the pipes to the back side of the blade, drill a cross hole in the shafts for a lynch pin, and if you want to get really fancy, hard-face the washer where it will be rubbing on your driveway. Adjust the height with washers over the shafting in the right spot. You can also buy the pin and shoe, because a lot of people wear through the shoe. I get a set from my fishing buddy every year to renew the hard facing he wears off during the plow season. And he has a spare set, so I get to weld while he can still plow. steveThat's an idea. Could you post a picture?. I'll be looking for small junked plows to grab a set of shoes.
Yup, a lawn broom and a scoop shovel, before the grass starts to sprout. I just got back indoors from replenishing the gravel on my lawn. 5 inches of heavy wet snow when the ground/gravel is soft. steveYep.
My driveway is pretty much straight, 300' straight up one way and 300' straight down the other.
A snow packed driveway is a skating rink after a mild spell and some rain. I scrape right to the ground and clean the mess up in the spring.
