Snow plowing
I just moved to NC, and we are suppose to get our first major snow by end of week. My question is, I have Kotoba four wheel drive tractor, and I have a rear mounted gradeing blade, that angles etc. Will this system move snow from my driveway without chains? As you can tell I am new at this.
Thanks so much.
Should...especially if your rear tires are loaded. I plow with a 4x4 JD 870 on hills and I have no problem. I have a grading box on the back and a plow on the front. Oh, I also have turf tires and it does just fine. I'm in snow country, NC isn't squat compared to the snow we get in Western NY.
It will do fine .In central illinois i use a New Holland TC26 FWD instead of the big tractors with 2 wheel drive as you can control it better and not leave blade scars in the yard come spring.
yes, you can. I kept a store lot cleared with a MF 65 & angled rear blade during a blowing snowstorm. Enclosed cab is a definite plus. And chains are always an improvement. Packed snow or ice covered by fresh snow is trecherous tho. Any slight grade & you take off sideways like a bobsled. The outcome is rarely favorable. During the winter '77 seven farmers were killed or seriously hurt locally in tractor accidents. No one had seen conditions like that in 30 years & had no idea what could happen.
I do it all the time with a back blade and 4WD. I have tire chains and the chains do well on ice. You may want to invest in a set of tire chains (rear tires only) My chains were $100 and well worth it.
Hey Bo, How is that front blade doing at stacking up that 50+ inches the news says you have gotten so far?
If I were down there I would leave it lay and let mother nature take care of it. It will gone in a day or so with no wear on the tractor or drive.
Drive over the top of it and if it is to deep to drive over, your not going anywhere anyway cause the roads will be unplowed as well.
I doubt your highway crews have any equipment to handle the snow.
Gary
If you have turf tires you are not going to move much if any snow without chains. If you have lugged ag tires you'll do OK as long as you don't get more than a few inches of snow or any ice.
I'm assuming this is a compact tractor.
Kubotas are perfect for that kind of thing. If snow gets a little deep you can try swinging the blade around so you can back into it and with angling capability you're practically home free.
This is great advice, use the tractor to pack it down and forget all the plowing stuff. Janurary thaw is just around the corner, especially for the south.
