Soapy water for leak testing
kopeck
What ratio of soap to water is used for leak testing? I know what I grabbed last night had way to much water (didn't have much "stick" to it, it was what I had left over from placing some decals). I did a quick google search and found 2 parts water to 1 part soap but that seems like a lot of soap.
I know I probably don't have to be very exact I'm just looking for a starting point.
Thanks,
K
I dont use anywhere near that much soap. what I find that really helps is the use of hot water. Im sure you can buy the regular stuff propane installers or tire shops use, but for no more then I ever need it, hot soapy water works just fine. I think I even grabbed some of the grandkids bubbles soap before IT REALLY WORKS GREAT and is cheap......
John T
I use the wife's bottle of Windex, or whatever brand she's using at the moment. I usually get it back before she even discovers it's missing. It seems to be the perfect ratio, and I don't have to fool with any leftovers.
I never mixed it heavy at all? Been more than once I needed some to check a tube or air pressure fittig when ma just happened to be washing dishes and dipped it ou t of the sink. Depends on how hardthe water is, in a pinch you can get away with close to none in rain water.
The only issue I've seen is that the more watery stuff I have mixed up doesn't seem to work on fitting that are vertical, it runs off before you can see any bubbles.
I think I'll just add some more soap and see how it goes.
K
I think you're over-thinking it. All you need is something that's going to make bubbles and show you the leak. The ratio is going to depend on whatever you are using.
I had to check a propane leak on an RV furnace yesterday. I put a few drops of Dawn dish-detergent in a cup and filled 1/4 with water. Shook it and saw bubbles so I figured it was good enough. Put in a spray bottle and sprayed the gas connector - and sure enough - in a minute or so I had bubbles coming out of the flare nut. I found a badly made and leaking flare.
We always have those little bottles of bubble making soap around for the grandkids. Works well;
I have even used it for mounting tires.
A friend of mind likes to "think out of the box".
When he was looking for a leak in his tractor tube, he put about a third of a cup of water "inside" the tube.
He inflated the tube and rotated it around while watching the bottom for the water to leak out.
Worked really well!
My super secret formular for soapy water that I use to check A/C lines with is a thinky of water and a squirt of soap. I use exactly one metric squirt of (brand name insert here) dish detergent. For real, it is just smething to make bubbles when pressurized air/gases leak onto it.
