soft plug removal
Moline_guy
Got to remove a large soft plug on a 404 JD combine engine tommorow to put in a block heater, any body got some tips to remove it the easiest? Usually i just hit the lower portion of one with a punch and it will rotate out, but this one looks like it might be stuck pretty good. Thanks for any replies.
Put a slot in it with a 1/2" cold chisel, then pry out one lip of the slot with a big screw driver. If it is stubborn, a slide hammer and hook tool behind that cut will pull it for sure. JimN
Hammer a big screw driver through it and pry it out.
If it falls in, grab it with some channel locks or just push it out of the way, and install your item.
I had one car went to the great auto recycler in the sky with a soft plug in the block. Never could get it out. Finally pushed it out of the way and installed heater. Try to PULL it out first, If you drive it in, you may not be able to get it out.
