Soil test results
Got my soil test back and while I added high mag lime this past spring I do not know where these other high #'s are coming from.
I am not to worried about the high PH because with 60" of rain a year this will leach out over time.
Looks like they are recommending a 2.5/0/1 ratio for my soil.
Can some of you guys that know fertilizer help me figure up what to mix that a home owner can buy.
We have a co-op that I can get the fertilizer from. I know they have 0/0/60 there but have no idea what kind of Nitrogen to even ask for.
Looking for a granular fertilizer not a liquid.
Thanks.
100 pounds of muriate of potash will give you 60 pounds actual potassium and 100 pounds of ammonium nitrate will yield 34 pounds actual nitrogen. Those would be the sources I'd go with, both can be had bagged if you are looking at small spaces. 1.5-50 pound bags of ammonium nitrate per acre on the strawberries and a little under a 50 pound bag of muriate of potash. I'd probably go with the whole bag, seems the stuff just gets spilled if it stays around. Pecans, looks like 300 pounds of ammonium nitrate and a shade short of 70 pounds muriate of potash.
Hope my math is correct but this is what I have come up with.
A conversion table I found says you need 2.3 lbs per 1000 sq ft for ever 100 lbs the soil test (acre) says you need.
I have 5 pecan trees that cover about 1000 sq ft each and the test calls for 100/0/40 per acre.
So I figure will need about 11.5 lbs of "N" (2.3 X 5 = 11.5) and about 4.6 lbs of "K" (2.3 X .4 = .92 X 5 = 4.6)
Since the ammonium nitrate you recommend is only 34% pure and the muriate of potash is only 60% that means I will need about 34 lbs of ammonium nitrate and about 8 lbs of muriate of potash to do all 5 trees (5000 sq ft).
Since my veg/strawberry garden is also about 5000 sq ft but the test only require 50% of the fertilizer (50/0/20) I just divided the above figures in half and came up with 17 lbs of ammonium nitrate and 4 lbs of muriate of potash for the garden.
This gives me a total of 51 lbs of ammonium nitrate and 12 lbs of muriate of potash (if my adding is right) to do both areas.
Thanks very much for the help.
If you had acid soil for a while the nutrients in the soil will bind with the soil particles and not be available to your crops. Then when you lime the drop in acidity unlocks the bound up ions and they become available so that may explain the high readings you got.
Nitrogen is volitile and you will lose it if it is applied when plants are dormant. Ammonium nitrate will evaporate faster than ammonium sulfate. I top dress hay with ammonium sulfate for that reason even though it is a bit higher priced.
