Solid core VS Stranded Plug Wires
Anonymous-0
Can anyone tell me where I could buy a set of solid core copper plug wires for my 48 Cub? I just got my new mag in and the instructions said to use "only solid core wires". WHY? Will I harm anything by using the stranded wire sets that are readily available through Brillman Co., OEM or Steiners?
Have you checked an auto parts store? The one right here in town handles them. 4-6 and 8 cylinder cut and build your own kits.
Im unsure if youre mixing up copper "stranded" core wire with single solid copper??? With such low energy levels when using a Magneto I prefer copper core wire versus any sort of suppressor or resistive wire or carbon core (which can reduce radio interference) because I dont want to waste any of the energy as heat (I squared R) or to drop voltage across the wires themselves, but instead discharge it across the spark plugs gap. I thought for sure Brillman offered copper plug wires instead of carbon core suppressor type plug wires, give them a call
John T
You want copper wire not fiberglass with carbon in it.The carbon shakes out of the fiberglas and you end up with an open wire.This fake wire has been in use since the 60s and has caused much trouble.
I think you are correct. I posted this questions in a couple different places and the sesnsus is I don't know squat about wire. That's why this is a good place to get the confusion cleared up. Thanks
Go to AutoZone. Tell the kid you have a'63 Falcon. He won't know how to find solid core wires any other way.
Nobody seems inclined to answer your question, but I'll opine that you simply need copper wire- doesn't matter if its solid or stranded. Just stay away from carbon or any of the other types. Unless you listen to the radio a lot on your Cub.
Less to wrong with solid core wires.
Resistor core wires are a semi conductor of graphite stuck glued onto a string and wrapped in high voltage insulation.
The graphite power or string can develop gaps that vary in size. As the wires age, vibrate, get yanked etc.
Pitch, that is assuming their computers go back that far and list a 63 Falcon. And if it did, you would have to tell the kid that the Falcon is a ford. And then he will ask if it has a V8 engine and you will have to tell him it was a 6 banger. I think I knew a couple guys that put v8s into a falcon for racing but I think they came with a 6 as stock. And then the kid will ask if it is fuel injected and you will have to tell him it probably had a 1 barrel carb.
I used to buy most of my stuff from Autozone but lately O'Reillys seems to carry more stuff and more off the wall stuff for tractors and such. And the counter help O'Reillys hired were moonlighting or out of work mechanics who had a little knowledge about stuff.
Like the old man said to his wife, "Get in the car Momma, we haven't seen everything yet."
I've never seen solid ignition wire or solid automotive wire or solid aircraft wire. All has been stranded and flexible so it will hold up to all the vibration. The only solid wire I've seen used is in short applications where it does not bridge between assemblies.
