Spark plug cleaning
gahorN
I removed and cleaned/gapped some spark plugs that looked just fine and had been running just fine, as they were practically new. But since I had them out, and since I had a spark plug blaster from the chinese tool store (a gift from a friend....I don't spend money there anymore).... I used it to clean the plugs.
The plugs all cleaned up ok, but two of the twelve (obviously this is not a tractor) instantly run poorly. They have a regular miss or an erratic one, depending on which plug we're talking about. (As a comparision, replacing them with old worn out plugs, the engine runs just fine, and the engine ran just fine prior to removing them and cleaning them.)
Here's my question: Is it possible that the aluminum oxide blasting media has shorted those plugs? I've double-checked the appearance and gapping, and without a spark-checker, I don't know what else to think.
THIS IS ONLY A GUESS, but I'm going to suggest there are some cracks in the insulator. Probably too small to be seen, but they could let some of the spark energy jump elsewhere besides the intended gap.
My only suggestion about how to determine that would be to set the offending plug up firmly on the outside of the block, where you can see the spark as it jumps, and see up inside the shell of the plug, and then run the engine in the dark. Maybe you can see erratic sparking.
I have a blaster/cleaner to clean plugs with the only problem I"ve had is that apiece of blasting medium will get stuck in the plug (can not have that ) have to get it out . I alwayscheck the porceline if it is cracked or chipped plugs no good. good luck Jer
well, visually they've been checked and re-checked but I simply cannot find any physical reason these plugs should not fire, and they've not been dropped or abused, ran fine until cleaned and re-gapped. Sure is irritating since they are specialty application and cost $24 each!
Test the plugs with a model T coil.The aluminum oxide may be coating the porclain.I see little need for cleaning plugs with sand blasting since we dont have lead deposits any more.I soak the JD plugs in lacquer thinner in a covered jar to get rid of carbon fouling and oil soot.Briggs and Stratton found engines were scored by blast media left in spark plugs.
