Speed-up gearbox
jCarroll
Location
mid-Ohio
I'm looking for a 90 degree gearbox which has 540 PTO input, and about 700-1000 rpm output. Needs to handle only 10-15 hp.
Got any suggestions of a machine I could find in a boneyard which would have such a gearbox.
Thx,
The gearbox from a New Holland or Vermeer roll baler might work. You flipped the gearbox for 1000 rpm tractors I think.
(quoted from post at 15:04:56 03/08/14) I'm looking for a 90 degree gearbox which has 540 PTO input, and about 700-1000 rpm output. Needs to handle only 10-15 hp.
Thx,
bush-hog type mowers may have what you want.
Looks like you will need either a 1:1.47 ratio box to give you 793rpm output at 540 rpm input speed or a 1:1.93 ration to give you a 1042 output at 540rpm input. What shaft configuration and mounting are you looking for?
Brooks AG Parts
540 PTO shaft input.
Output can be anything I can put a double sheave vee-belt pulley on.
Mounting lugs, or tapped holes to fit whatever mounting frame I need to construct.
Sounds like just a simple rotary cutter right angle gearbox would work, get the blade hub with the box and you can weld the pulley to the hub for easy mounting, hp rating might be a little higher than you are looking for at 40hp but at $170 delivered price it is pretty reasonable. If you pm me I can send you dimensional drawings of the box for you to review to see if it will work for you!
