splitten wood
It would work well if you added hydraulic pump to the front of the crank, or a PTO mounted pump, effectively having a separate hydraulic system.
I BUILT A WOODSPLITTER ABOUT 5 YRS AGO. I HAVE RAN IT SUCCESSFULLY OFF OF MY WD. HAVE NOT HAD ONE PROBLEM. IT SPLITS MY WOOD AS FAST AS I WANT TO GO. MOST YEARS I SPLIT ABOUT 10 RICKS OF WOOD. GOOD LUCK. BUY AMERICAN
Need to match to the right cylinder. Tractor runs about 3200 psi, maybe 5-7gpm. I believe the D17 is 7 gpm, WD would be similar, smaller if anything. Right gives you normal speed and push.
I have dads WD45 set up with a 2 way hyd. Bought a 2 way cyl for high pressure, you can split all the wood you can get to the tractor in a very short time. It is far faster than the neighbors 12 hp gas factory set up.
