Splitting M
Ruegers
I am trying to replace the clutch but need to know how to split the tractor. First time splitting a M Farmall and I need to know if I need to remove any other items in addition to the frame bolts. I have removed all the normal hood, steering, etc, but do not know what the U Joint Woodruff Key is. My manual says to remove it but I have no idea. Can someone please let me know? Thanks.
yYou don't have to split a M to replace the clutch. Drop the hyd. box. Take apart the coupler joint. There are thread in the pressure pate to put bolts to pull it together. It will all drop down from below.
Ditto on what Bill said! You do not have to split it to change the clutch, UNLESS its a late M with the bigger clutch. If thats the case, the Woodruff key they are refering to is a key in the shaft the steering wheel goes on where the ujoint is. Ive only had one with an accuall key in it, the others are a fat washer.
Shouldn't have to split the M to do the clutch. Even on the later models or the Super M. What I've done, is put in longer bolts in the frame mounts and slid the tractor apart a couple of inches. Once job is complete, take a come-a-long and pull it back together if you aren't able to slide it back with the bolts.
Like the other have said, you don't need to split the tractor. Put in some bolts to relieve the pressure plate. undo the coupler from the shaft and the tranny. loosen and remove the six pressure plate bolts. and you will have maneuver the pressure plate, shaft and disk as a unit, in certain position and it will drop out the bottom. reverse and reinstall. I did this two years ago on my M.
