stalling farmall cub
Anonymous-0
I have a 1955 farmall cub I have just had the engine rebuilt and it runs fine for about an hr.the it stalls and will restart for a few seconds .I have changed the points,condenser and coil and it still does it.I'm stumped the carborater,fuel bowel,and gas line are also new.I would appreciate any advice I can get.
The next time it does that carefully pull the gas cap off and see if you here a suction or here pressure coming out of it. Then with it off try to run it and see what happens. You may have a clogged up vent in the cap and that will cause a problem like your having
You need to pull off one one of the plug wires asap when it quits running and have someone make an attempt to start the engine to see if you have fire to your plugs. If you have a good hot spark to your plug then you have a fuel problem.
Loosen the gas cap to make sure the tank is vented. If it has a ballast resistor between the ignition switch and the coil it could be the problem. The next time it quits hold your hand over the throat of the carburetor and see if it has good suction. You need good manifold vacuum to suck that gas into the engine. Your valves may be set too tight once the engine gets hot. Hal
Well I ll give my two cents. Is the vent on the gas cap plugged up? Do you have anything floating around in your gas tank? You replaced everything else that I can think of
Could it be the gas? New gas takes up moisture. I have had with trouble with cars pickups and tractors not wanting to run sometimes after running for a while with farm stored gas. Haven"t had filters on our tanks. We put in gas antifreeze to make stuff run. Some say to use stayput.
