I recently acquired a MF 50 tractor and it has a 12 volt system with push button start and a toggle to turn power on and off to the points. Didn't run when i bought it and when i put a fresh battery on it, the motor and starter turned over perfectly with the push of the starter button. I walked away to get some gas and emory paper, and when I returned the push button acted as if I removed the battery from the tractor.....it did NOTHING. This tractor has a Ford style solenoid wired on it so all I did was take a screwdriver and jump the top post going to battery with the small "start" post on solenoid and that turned the motor over perfectly just as if I had used the starter push button. NOW......I HAVE 2 problems.
Problem #1: The push button will work when it wants to. Some times it will and sometimes it acts as if there is not even a batter in there. What causes that???
Problem #2: Upon trying to move the tractor in my shop after I have started it and driven it 6-7 times; it now only "clicks". I used the starter button and it did a "click" "click" "click", etc. I then used a screwdriver on the solenoid as before and I got the same "click" "click" "click" "click". No go. Now what gives. I don't want to drive 1 hour to the starter shop only to find out it is something else. Please help me in learning how to diagnose these problems and know what is wrong.
