STARTER FOR A BF AVERY MODEL A
Anonymous-0
DOES ANYONE KNOW IF THERE IS A STARTER THAT WILL FIT A BF AVERY MODEL A BESIDES THE ORIGINAL? IS THERE A SUBSTITUTE FOR THIS MODEL?THANKS TIM
NO The Oliver OC 3 uses the same starter. Anything with a Hercules I X B engine uses this starter. If you have a good frame a auto electric shop should be able to replace the coils if they are bad. The rotor will be harder to do. Some air compressors used this same engine but I don't know which ones. And no I will not give up my spare starter.
John
HI JOHN, THANKS FOR THE REPLY ON THE STARTER , I WILL CHECK WITH THE LOCAL TRACTOR SALVAGE AND SEE IF THEY WOULD HAVE ONE ...THANKS TIM
