Starter Problem
I have a 8n and the starter finally has gone as I have never removed one of these before I thought I was being careful however the spring on the end of the starter fell down behind the clutch plate. I am looking for help as to any one tis has happend to and how they resolved the problem or any suggestions or is it ok to leave this spring back where it fell. As I see it the only true was to retreve it is to break the tractor apart.
I doubt that it's a spring from the starter. More likely than not, it's off of the bendix. Regardless, don't worry about it. Probably 75% of all N's have had or still have pieces of the bendix in the bottom of the bell housing. Lots of room in there.
To remove the starter, unscrew the bolts out of the block & put a nut on one of them. Otherwise, the starter comes apart. Not fatal, but not fun either. (tip # 36 at the link below) Then, loosen the two bolts holding the oil filter canister to the block, (it does not need to be removed) remove the dipstick, and keep the starter close to the block while pushing the front of it down and lifting the back up. Sometimes you have to remove the drain petcock as well.The bendix is behind the flywheel; your job is to get it over the flywheel.
Caution: while the starter is off, resist the temptation to screw with the bendix. If you extend the bendix, and it is not the OEM bendix w/ the big spring, you will have a hard time getting the starter installed.
To install the starter, keep it close to the block while pulling the front of it up and pushing the bendix back into the hole. The bendix has to go behind the flywheel; your job is to get it over the flywheel. Grinding out an egg shape at the 2 o'clock position before you put it back will make your life easier.
Lastly, while the starter is off, polish the block & starter mating surfaces w/ sandpaper to insure a good electrical ground between the two, and clean the mating surfaces where the starter's "belly" meets the aluminum endbell. The starter's ground circuit is through that "joint" as well was through the starter endbell-to-flywheel housing joint.
50 Tips
Mike.......would you believe Ford designed starter parts storage space in the clutch housing with the dangln' cotterkeys??? There is 'nuttin' down in the cavity that can gitt damaged. The parts will just bounce around until you split the tractor for other reasons. Of course, the sphincterly challenged would try to retrieve it with "magic fingers" 'cuz magnets won't work in a cast iron chamber. I say leave'm bee. ......Dell
Thank you so much Bruce I truly appriciate your knowledge and it really helps me out a bunch, since I am not all that familiar with this tractor.
Thank you John now I can sleep tonight and not worry about figuring out how to split this baby to get it out. One question for the three of you is what happened and prompted me to take the starter out is when I turned it over the only thing I got was a whirling sound no engagment of the bendix to the fly wheel, I am going to guess I am in need of a new starter? And a bendix spring.....
Mike.........yer starter motor is OK, its just needs a NEW BENDIX. Eazy to replace once.
Put some 5/16" nuts on the LONG starter screws so yer starter motor don't fall apart.
Gitt the NEW IMPROVED "CLUTCH" style starter drive. Well worth the extra money. Gently clamp yer starter motor shaft UPSIDEDOWN in yer vice so you can use yer armpit to compress the springy thingy so you can hammer the roll-pin into the starter shaft. Some even "grind" a taper on the roll-pin for eazier insertion. simple, eh? ......Dell with dirty pitts
Mike.......would you believe our host, Yesterdays Tractors, sell'em? As do alotta other agricultural emporiums. You doubt? At the top of the left sidebar is title called "Marketplace" and underneath is a listing called "tractor parts". just navagate yer way to the 8N-Ford parts pages and vola , down at the bottom of the page waddda'ya know??? Starter Bendix's fer sail. Isn't that amazing? .......respectfully, Dell
