Starter Problem
I just installed a new starter on my 8n but it will not start and I know something is hooked up wrong. Before this swap when the key was not in the ignition and you pushed the starter nothing would happen, now in the same situation when you push the starter the engine turns over but will not start. I have the solenoid on correctly starter wire to the small end positive battery cable to the end that says battery and the wire from the amp meter on the positive side any help would be greatly appreciated.
(quoted from post at 17:14:19 06/13/09) Even with the key not in it will turn over?
ep! David..............
Thanks Dave I have er' wired right Murphy's law must have been enacted as something has gone esque while I was changing the starter out.
It was wired wrong to start with & rewired wrong as well. As you can see from the diagram, the key has nothing to do with the starting circuit. W/ the key off, you can press the starter switch & the starter will turn over as long as you have battery power to do it, but the engine will never start because no current is getting past the ignition switch to the coil.
50 Tips
If you have the correct solenoid, the small terminal goes toward the engine block. Backwards - small terminal out - it will not work.
