(quoted from post at 01:25:16 09/28/09)
(quoted from post at 02:29:46 09/27/09)
(quoted from post at 10:46:11 09/26/09)
(quoted from post at 10:37:20 09/26/09) When you crank an engine over,if something is not right,like a battery being run down,or something not making a good connection or a switch sticking it could cause the starter to stay engaged.If something like that happens see if it has any connections that are hot.That will tell you there is something wrong with that connection or cable.Low voltage will cause this to happen.I dont know why,it just does.
The reason it does that is ohm's law.
The less the voltage, the higher the current flow.
The more current causes the solenoid contatcs to "weld" together lightly.
I am going to try to give this one farther (and teach ohms law if you will), I already attempted it in another topic lately.
If your starter happens to be a (example) power appliance of 1200 Watts Power.
Then if you apply 12v to that appliance....
You have: I = P/E
1200 Watts of power, at 12 Volts = 100 Amps of current.
Now lets drop our voltage.....
1200 Watts of power, at 6 Volts = 200 Amps of current.
Now lets try it with a battery that is not fully charged...
1200 Watts of power, at 4 Volts = 300 Amps of current.
Ohms LAW.
There is a flaw in your application of ohms law, Power is NOT a constant. Just because a device is rated for X number of watts doesn't mean its going to get, or use that amount.
example 1: 100volts x 1amp = 100watts of power
example 2: 50volts x 1amp = 50 watts of power
We can see that power follows voltage.
example 3: 100volts x .5amps = 50watts of power
example 4: 100volts x .1amps = 10 watts of power
We can see that power follows current as well.
To make a long story short, power is a function of voltage and current, not the other way round.
Resistance on the other has just the opposite effect. The short rule is more resistance = less current. As in bad connections etc...
At least thats the ohms law they taught us here in Kansas, is it different where you are?
