I'm close to resolving my electrical woes;
after replacing cables and regulator, etc., I finally had the starter tested and installed a aftermarket Lucas starter on my '72 deisel.
Started and ran better than ever twice.........3rd, 4th and 5th starts, the starter won't shut down...evan after disconnecting all wires from the ignition switch; the only thing that works is pully the battery cable.
put the cable back, nothing until I turn the key again.....and then it won't stop again.
The new stater has a stud on the starter casing that wasn't there on the original, is this an additional ground?
As always, any suggestions greatly appreciated.
