Paul in Edmonton
Last year was a heavy snow year, and by the end of the winter, we had too much snow for the 8N to handle. We have almost as much right now, and it's not even Christmas yet...
Anyway, while trying to plow yesterday, I was having steam coming out of the radiator. Not a good omen. (The 8N lives out at my cabin, an hour north of the city.)
Background:
1. '49 8N, front mount. Pretty much original except the genny is not an original Ford. Still 6V, though. And the solenoid is wired for a key start. (I intend to fix that next time I'm ordering parts.)
2. The radiator is NOT overfilled.
3. The radiator is not designed for the 8N. It fits in place reasonably well, except the cap doesn't fit perfectly through the hole in the sheet metal. It was new when I bought the tractor a few years ago.
4. The fan is spinning and providing good air flow (pulling towards the engine). This of course means the water pump (or at least its shaft) is turning--but I have no way of knowing if it's actually pumping.
5. The temperature at the cabin yesterday was a few degrees above freezing. (Although the min/max thermometer had bottomed out at -40 sometime in the past three weeks, since I last reset it.)
6. I pulled the dipstick after using the tractor yesterday, and the oil on it looked clean--no sign of water in it.
Anyway, there were a couple of odd things I noticed at the time.
The first is that the oil pressure was decent--I've seen it a lot lower in summer. If the engine was overheating, I'd have expected the oil pressure to go lower--at least down to where it gets in summer.
The second, and more significant, is that the steam didn't seem to be coming out the cap. There's also an overflow tube coming out of the stem just below the cap, and nothing was coming out it, either. I couldn't tell just where it was coming from, since it was all under the sheet metal. Most came out from under the sheet metal where the cap protrudes, but sometimes it also came out lower, being blown back by the fan. It was only coming out when the engine was working under a heavy load (like when the plow was getting overloaded), and for a few seconds after. Running without a load--no steam. It would also spew for several seconds after I shut the engine off, even if it wasn't steaming or under load right before. I have seen no evidence of a leak in the rad--no visible accumulation of coolant below the tractor--and like I said, the rad is pretty new.
Any ideas what to look for?
-Paul
Background:
-Paul
