Sticking Clutch Pedal
Anonymous-0
I have a New Holland 5610 tractor with about 1000 hours on it. It sat in the shed unused from Oct. until Apr. Now the clutch pedal is sticking. It has about three inches of freeplay in the pedal. If I push the clutch down to the end of the freeplay and take my foot off, it will stay at this point. Also when the tractor is being used, when letting the clutch out, it will stop at this point. It goes into the gears with only minimal grinding. I have greased all of the linkage, but it has done this all summer. Any of you tractor experts have an idea of what"s going on and how to fix it?
First guess would be that you lost a return spring. The springs in your clutch cover will only return the linkage and pedal to the limit of your free play. There ought to be another spring there somewhere (the simplest would be a spring between the pedal and some point on your chassis, but it could be otherwise or elsewhere)) that will bring your pedal the rest of the way up.
Here is the diagram of the clutch linkage notice the small return spring.
Walt
<a href="http://s77.photobucket.com/albums/j50/WaltDavies/?action=view&current=5610clutch.gif" target="_blank">
5610clutch.gif" border="0" alt="Photobucket
</a>
<a href="http://s77.photobucket.com/albums/j50/WaltDavies/?action=view&current=5610clutch2.gif" target="_blank">
5610clutch2.gif" border="0" alt="Photobucket
</a>
Thanks guys for the information and the drawings. My daughter is keeping me on the run with all of her volleyball and softball, but I should be able to check out the tractor in about a week and see if this is the problem. Thanks again.
