fordfan19422n
Can't figure out what's going on with my tractor. It is a 2N with an 8N engine. Front mount distributor. The trouble first started with the engine dying after being in use. Tractor would then start after sitting for awhile. Determined no spark. I bought a tune up kit that included points, condenser, rotor, cap, and plugs. I got the tractor to run briefly. I also had to do a water pump replacement when I discovered a leak while working on the electrical system. After the water pump job, the tractor started and I was able to check to make sure the new pump didn't leak around the gasket. All was good with the pump. I drove the tractor around for a bit and then let it idle. It sounded like the engine was not firing on all cylinders. I throttled the tractor down and the engine died.
I have not been able to get the engine to start since. I pulled each plug and checked for spark and each plug had blue spark. I also disconnected the fuel line at the carb and there is good flow from the tank.
Now when I crank the engine over, all I get is a few seconds of cranking and then an exhaust back fire that sounds like a 12 gauge shotgun going off. So fuel is apparently getting in the exhaust before igniting.
Any ideas? I am about at my wits end.
