Bern
- Location
- Mount Vernon, WA
Being stuck at home makes a guy do some pretty weird things. Here's my latest project. I'm dialing in a generator regulator for my 6000. Because I want this tractor to be as original as possible, I'm not going to convert it over to an alternator, which is the first thing I'd do if I wasn't restoring the tractor.
Even though I'm striving for originality, I think I'm going to ditch the "2 unit" voltage regulator in favor of a 3 unit like the 5000 tractors had. The 2 unit combines the voltage and current regulators into one coil, whereas the 3 unit separates them out. I have found that it's very difficult to get the 2 unit style adjusted even remotely close for both voltage and current specs.
Adjusting the 3 unit regulator is no picnic either. The adjustments are extremely sensitive, and I found it difficult to not go either too high or too low with the adjustments. I finally got her dialed in to 14.0 volts and 27 amps output. Now if it will just repeat that same performance tomorrow!
In the pic you can see a variable speed test bench with a 1HP motor. I let the system run for about 20 minutes first with a 15-amp load to get everything warmed up to operating temp. I then apply excess load with the box full of light bulbs to set the current regulator. After that, I remove the load completely and let the voltage stabilize to adjust the voltage setting.
You can also see that I have an oscilloscope hooked up to look at the output waveform. I had two different generators to try; one had a very dirty and worn commutator, and the other had a good clean one. It could be clearly seen on the scope.
