stuck engine oil
Sounds like it's only good for very lightly stuck engines, so basically jus about any engine that the guys on here have would probably not qualify for "stuck during storage" like they claim.... Unless of course that storage is sitting outside for 30 years without a raincap...
Donovan from Wisconsin
Got A WD45 sitting out back that is stuck, it says it is guaranteed, I might have to order a couple "kits" and see if it works and if they will honor their warranty, this has been stuck for about 2 years.
Jim
$19.95 for 250 ml. By the time you bought enough of it to thoroughly treat a tractor engine you would have a good start on paying for a complete engine rebuild kit, which you are still going to need because even if the magic oil managed to do the job, you would still have pistons and sleeves that are severely pitted and beyond use. Just my opinion of snake oil.
You mean you don't wanna try it out on a 6 cyl. engine right away? It'd only cost $120+ S&H..... Hmmm.....
and from the post earlier, mixing atf with acetone 50/50 was the super duper penetrating oil!!!!! i gotta mix up a batch and try it to see how it works.
.we used air pressure to free 330ih, removed the rocker arms and sparkplugs, put 120# of air on the front and rear cylinders rocked the back tires with the trans in high gear it turned 1/2 turn. Then moved the air 2,3 rocked again turned complete circle.
