I'm a 39-year old university educated man without a lot of mechanical experience, but I'm good at figuring things out when I have to. That's just a disclaimer to indicate my rudimentary level of knowledge and that I may be unfamiliar with what are thought to be common terms regarding the kind of work I'm trying to do. Bear with me!
I recently picked up this old girl, a 1966 AC HD4 with loader and an AC Industrial-600 backhoe. She runs great and I've been working on doing a full service to her (replacing all fluids and filters) since I'm not sure when these things were last done. I should note that I have the operators manual and service manual for the HD4, as well as the service manual for the backhoe (but no operators manual).
I've lightly used it for a couple hours at a time to start digging up some stumps with the backhoe. I probably got about 6 hours in with no issues over 3-4 sessions.
However, when I went to use her for some stump digging again the other day, I ran into a big issue. I was pulling in the dipperstick on the hoe a little bit and when I released it all of a sudden it wouldn't return to neutral like it normally does. The dipper just kept coming in and wouldn't stop, and once it fully retracted you could hear the strain on the hydraulic system as it keeps trying to pull the dipper in. No amount of pushing/pulling on the lever arm resulted in it being able to return to neutral (or push the dipper out). It would appear there is a problem with the spool valve.
I should note that the lever (and the spool valve) can still be pulled out a little bit (as if you're trying to retract the dipper faster) but when you let go it just stops and won't return to neutral, not even when you try pushing hard on the lever. At the very least this indicates that the spool isn't pinched or otherwise seized as it can still move 'freely', it just stops at some kind of obstruction instead of travelling all the way back to neutral (and beyond) like it should.
I got underneath and it was pretty grungy under there, but in this photo you can see the guilt valve sticking out further than the rest.
I got out the pressure washer and gave everything a good spray down to clean up the area. After many hours of hardship,l I finally managed to get the pin out that holds the rod that holds the control levers in place, and disconnected all the control lever linkage from the ends of the spools.
I suppose my question now is what to do at this point. Research so far has led me to believe that I need to pull out the spool and clean it/check for obstructions etc. Probably needs new o-rings etc. But before I go any further I'd like some confirmation from knowledgeable folks that I'm on the right track.
Also, I'm feeling a bit discouraged at the moment because the next foreseeable step is to remove the cap for the spool and/or the relief valve, which is on the other side of the control valve block from the side the control levers were connected to:
In order to get at these things, I have to be on my back under the machine, reaching way up, because there's no other way to access it. What's more, is that there's not a whole lot of clearance between the ends of the caps and the back wall of the HD4 itself, so even if I were to get the cap off I don't think I'd be able to pull the spool out all the way before it's hitting that obstruction.
I'm really hoping there's a way to fix this without having to detach the backhoe from the machine, because I don't know how I'd go about doing that with the limited resources I have. I doubt I'd ever be able to get the hoe back onto the machine if I took it off.
Sorry for the novel of a post. I'm really hoping someone will be able to help me out in getting this solved.
Cheers.
