(quoted from post at 13:43:11 11/10/11) Soak threads with WD-40 for awhile. Then pull up on steering wheel while someone else taps the steering wheel from underneath. I usually use a 3 lb hammer and alternately tap each spoke from underneath. Works for me about 90% of the time.
Brian
(quoted from post at 10:36:53 11/10/11) Hello, i have a 53 jubilee, i want to paint the dash, i have to remove the steering wheel but it's stuck on pretty good, the top nut will unscrew but the wheel does not buge, i tried hitting it off but did not work, what would be the best way to remove the steering wheel. thanks
