I fill the cylinders with ATF and also pour as much as I can down the exhaust. With the hood off you can push/drive the valves down by way of the spark plug holes but be careful not to damage the treads for the plugswhat’s the best way to loose stuck valves in a 8n tractor? atf in the spark plug holes,
Must have forgot what the exhaust looks like on an 8N. As far as I know he still has me on ignore.with ATF and also pour as much as I can down the exhaust
He has most of us on ignore. Saves time reading YT when you only see half the posts.Must have forgot what the exhaust looks like on an 8N. As far as I know he still has me on ignore.
they stick when warming up after about five minutes the all workAre the valves stuck now, and won't move? Or does the tractor run for a while, and they stick when warmed up?
I use Marvel Mystery Oil in the gas and the oil when that happens.they stick when warming up after about five minutes the all work
Mix a quart of ATF to 3 gal of gas and run it that way. The ATF cleans and lubes the valves as it runs.they stick when warming up after about five minutes the all work
a quart in the gas? wow, does that work? and a pint in the oil? in the gas tank do you jut the quart in at half a tank or what ever!I use Marvel Mystery Oil in the gas and the oil when that happens.
It's cheap and has always worked for me.
Put a quart in the tank and a pint in the oil.
ATF does the same thing at half the cost but it doesn't smell as good LOLa quart in the gas? wow, does that work? and a pint in the oil? in the gas tank do you jut the quart in at half a tank or what ever!
That will work in a half tank of gas.a quart in the gas? wow, does that work? and a pint in the oil? in the gas tank do you jut the quart in at half a tank or what ever!
MM oil smells like Pepto BismolATF does the same thing at half the cost but it doesn't smell as good LOL
I see $8.99 per qt for Marvel Mystery oil and $12.99 to $22.99 per qt for ATF at O'Reilly's. And I agree, MM smells better.ATF does the same thing at half the cost but it doesn't smell as good LOL
The stems and seats have to be shined up. I would get it running and when it starts having valve problems, shut it off and let it cool. When cool, repeat the process a couple of dozen times. When you get the can kicked down the road you may be pleasantly surprised. I just finished with a Ford 3600 that I thought was worn out. Didn't expect it to have been run just a few minutes repeatedly , or sitting up and not running since I bought it from a tractor repair business as the root cause of my findings.I use Marvel Mystery Oil in the gas and the oil when that happens.
