X 2. If you can also soak down the gearbox shaft top and bottom with your favorite penetrating oil, that will help. Don't be scared to hit it hard either.Is there an access hole on the top to remove the nut from the blade bolt? If so, I have used a solid steel rod, about the size of the hole, and whack it with a sledge on the heavy steel crossbar. Then rotate to the opposite side, and just work it back and forth. Most I have seen are tapered shaft coming out of the gearbox, so they can be stuck on pretty good.
I removed one but was also replacing the gear box. I ended up cutting the shaft on the gear box and put the thing in a press with lots of Kroil and then some heat to get it apart. Put allot of anti seize on it when I reassembled it but don't know if it will help it If I tear it apart again.Those are notorious for getting very stuck. The general appearance of yours makes it look like it may be the worst one ever.
I agree with Cat Guy, heat and let cool, applying "loosen juice" as soon as it cools enough not to set the stuff on fire.If you can get some heat on the top side it would do the most good for you. Then squirt some squirrel pea in the crack on top. Let set and cool then heat again if you could put some pressure on the end of the shaft while heating it you might get it off the first time.
