Crazy Horse
I've have the lower end chain case apart on my older 5 hp MTD front tine garden tiller. I noticed the online manual specifies to use some brand of special oil/grease (forget the exact name) but I've been told it is the same/similar to JD Corn Head grease. I believe corn head grease is a very sticky heavy oil OR a very sticky light grease compound.
The online cost is outrageous for that stuff, I haven't even checked around to see if anybody has it for sale locally. Obviously I want to use something in its place at a lesser cost. This tiller gets used once every year for about an hour. Is there something else I can buy .... or even make up myself .... that would serve my purpose in this situation?
Regular gear lube I don't think would work very well. While the case itself and main perimeter gasket is relatively leak proof, there are some spots where inner shafts are mounted in the housing that aren't exactly "oil tight" and they were that way from the factory. Hence the need for something of heavier viscosity.
Any suggestions are appreciated.
