Super 55 diesel injector pump
Larry Hirt
I have a Oliver Super 55 diesel. What is the proper way to time the diesel injector pump and what is the firing order. I seem to be having trouble getting it just right. I am getting close but could use some help.
Firing order is 1-2-4-3. Now on your pump timing. Does it run now? What marks were you lining up? Now it does have a Bosch pump correct, no change over to a Roosa Master
Yes it has a bosch pump. It was running but i removed the pump to repair a crack in the water jacket and when replacing it got it out of time. One the front of the pump there is a flat plate that the timing gear slips up on and it has a hash mark on the side of it. This mark i was lining up with the pointed indicator that is visible thru the site hole when #1 cylinder is TDC on compression stroke. The flywheel also has a stamp of INT.
