Anonymous-0
Ok guys, here goes. I've owned a Super 55 for the past few years and was recently considering "trading up" for an Oliver 1365. Turned out that the 1365 had some issues that were corrected and seems to be pushing it a little out of my comfortable price range, although in excellent physical and mechanical condition.
My Super 55 is a 1955 gas model that has the hydraulic cover upgraded to 550 specs. I've replaced the seals in the hydraulics, including lift arms. It's fairly tight overall (as far as leaks are concerned) and the front end is also tight despite having a HEAVY Wagner loader on it. It is equipped with power steering.
After replacing the coil, condenser, and fiddling with the adjustments on the carb, I think it's starting to run pretty good. It does need rear tires, a minor leak repaired on the power steering, new plugs, and fluid/filter change all around. Right now, other than the expenses of what I just mentioned, my only major concerns I have are with the condition of the 3-pt hitch.
The hitch has been used extensively, so most of the holes are good and wallowed out. The adjustable link also has worn threads and does not have full adjustability. Is it possible to repair these issues without replacing (bushings)?
I love the nostalgia of the Super 55, but some part of me thinks the money would be better spent to upgrade and update than to invest in a 53 year old tractor.
Just looking for thoughts and/or opinions if you were in my shoes.
Thanks,
Justin
Thanks,
Justin
