We've got a 1955 Super 55 Gas that we just got. It seems to have a vibration. Sitting in neutral not moving, at idle, there seems to be little or no vibration. At about 1/3 throttle, it vibrates the entire tractor - hood, seat, fenders, everything shakes. As you increase the throttle from there, it gets better, but still vibrates everything a little. The clutch and brakes don't seem to effect the vibration at all and it seems to vibrate the same when driving it. I dont know what can be causing this. My dad thinks it may be the water pump going out - as sometimes you here a quick little squeal from the front of motor and the fan belt belt pulley isn't lined up very good with the crank and generator pulleys - bad enough its tearing up the new belt I just put on. Any ideas on what would cause this vibration or things we can check to see what it is? Thanks for your help.
