I used the Flourescent UV Leak Dye and UV light that I got from
Autozone in my Super A that has leaks on both the front and back of
the engine.
On the front oil was leaking around the seal on the V belt pulley on
the crank shaft. There appears to be a slight worn spot on the pulley
shaft. The seal itself is about 2 years old or less.
On the rear of the engine the leak appears from what appears to be a
frost plug or a machine hole. There are two plugs on the back above
the flywheel, one on each side of the block. So do I get a new plug or
try to seal the plug that is there? What type of sealant would work
with engine heat and vibration and last for 50 years?
the engine.
