super a hydraulic leak
Anonymous-0
i have a super A and have a international 1000 loader on it. seems the hyd. fluid keeps getting low. seems to be getting into motor oil. is that possible. could it be an oil seal at hyd. pump gone bad. looked up diagram and parts list at ihcase.com. looks like there is an oil seal in pump. please any info will help.
There are some o- rings in the pump that when they go bad will allow your touch control oil to drain into the crank case. Not a hard job to replace. Sometimes the shaft will have a groove wore in it and will need a speedy sleeve. I have not had to do this myself.
Here's a breakdown on the Pesco hydraulic pump.
The old seal sometimes wear's a groove in item No.11. It can be covered with a speedi-sleeve as Paul suggested. Napa has this speedi-sleeve and Case/IH may have it too. Hal
